Hi all, I was wondering if anyone knows of a solid trick to delete all unused nodes from the Hypeshader? The command printed out in the script editor (with and without ‘echo all commands’ on) doesn’t produce anything useful.
And since the command is in the hypershader menu, I am unable to ctrl drag it to the shelf to investigate the mel there either.
I have a silly workaround, which involves deleting shaders without shader engines attached… and then I delete shaders with shading engines attached but that have NO polys assigned to it.
wtf, isnt there just a command for this???
Thanks for any help you can give folks,
Ken
