Has anyone had any success manipulating layers in Max using MaxScript? I can’t seem to find any good documentation on the process or examples that don’t involve animation layers.
Are you talking about Scene Layers or Anim Layers? You have a double negative in that second sentence and I’m not sure which you aren’t talking about.
In either case the MaxScript help file has documentation for LayerManager and AnimLayerManager. It would help to know which version of Max you are using.
But to answer your question directly, yes I’ve had success manipulating both Anim and Scene layers. Is there a specific task you are trying to perform?
Matt, check the MXS help docs for the LayerManager class.
LayerManager class was the answer, thanks Jeff.
