Results 1 to 7 of 7
Thread: Importing Collada crashes Maya
  1. #1
    Default Importing Collada crashes Maya
    Hi guys, I'm having a problem when I try to import some of the artists' DAE files into a scene. As soon as I try to import one of their files, Maya crashes. I can import DAE's I generated myself, and they can import mine (and theirs) as well.
    At the top of their DAE (in a text editor), I see the version listed as 1.4.1. Mine are listed as 1.4.0. The only thing I can think of is that I'm using Maya 2011 while they use 2012, which must have a different version of Collada.
    Is there anything I can do about this? Update my version of Collada or something? I don't think I'll be able to sell an update of Maya for this issue alone.
    Thanks
  2. #2
    undefined
    Join Date
    May 2009
    Location
    Shanghai
    Posts
    2
    Default
    This is probably not a very helpful reply. But I needed to get a Collada file (the collada file I had came from Google Sketchup) into Maya 2011 a few days ago and had all sorts of problems.
    I ended up installing Blender and converting the file to .obj (I'm not sure if that's a possibility for you). Blender imported the file fine and obviously the obj file worked in Maya
    I guess that would be a "nuke it from orbit" solution
  3. #3
    Default
    I assume your using the FBX plug-in to export your collada's. So you could try updating your FBX to the same version.
    -Dave
  4. #4
    Default
    Actually, I'm wondering how I can accomplish that very thing?
  5. #5
    Tech Art akira's Avatar
    Join Date
    Apr 2009
    Location
    Hyderabad, India
    Posts
    25
    Default
    Quote Originally Posted by GearSpinner View Post
    Use Google :)
    http://usa.autodesk.com/adsk/servlet...12&id=10775855
    Akram 'Akira' Parvez
    Technical Artist
    http://www.akramparvez.com/
  6. #6
    string
    Join Date
    Jul 2008
    Location
    Vancouver
    Posts
    89
    Default
    Sounds silly but did you try changing that 1.40 to 1.41 ina temp copy and importing it..
    Obviously hacky but sometimes it works.. Same as just dragging the file into the viewport instead of via the import menu seems to go a slightly different route sometimes..
  7. #7
    Default
    Excellent, Akira, thanks!!! I was thinking it was a third party plugin when my previous google searches weren't leading me to Autodesk, but to OpenCOLLADA and a sourceforge project.
    rhexter: funny enough, I did try that, without luck. Its a fair idea, I've done that to artists' MA files to get rid of that "scary" data loss dialog as you exchange files across versions.
    Thanks for the responses, everyone!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
