Results 1 to 3 of 3
Thread: [Mel] Waiting for part of script to finish?
    Default [Mel] Waiting for part of script to finish?
    Hello.
    Im writing a script that will automatically do all of the following at once
    • create a spotlight,
    • create the RSL shadow attributes needed like deep shadows
    • put a variable in the shadowMap name so i can manage this in another place
    • attach a rsl uberLight shader to it and a custom viewport visualizer
    • move it to 0 10 0
    • look through it
    I am very close to doing this - however! I have to execute the code in two stages to get the RSL attributes to attach to the lightAttributes of the spotlight.
    I want to do it in one command. Probably an if statement?
    I'm using a proc
    AE_reselectTabIndex
    that was included with 3delight which make me able to select the fourth tab in the AE and then i can get the name of it with the maya proc $gAECurrentTab and then filter it with startString.
    However, when I run this all at once it doesnt work and when I try to print the result of $currrentNode i just get $currentNode unless like I said I execute the the second part after the first I am probably going to have a lot of lights so I need it to be dynamic and depend on this variable. I figure that if I have more than 9 lights i can run an alternate version of the script that does
    $currentNode = startString($gAECurrentTab, 21);
    instead of 20.
    I've done a lot of research, been working on it for 2 days now. Ive tried return arguments, eval deferred, timerX, splitting it up into (global) procs etc but they arent working.
    Any help is appreciated. Im sure this is a common question.
    defaultSpotLight(1.5, 1,1,1, 0, 40, 0, 0, 0, 0,0,0, 1, 0) ;
    DL_shaderAssignmentPanelCreateNewAttribsNode delightLightAttribs object;
    dR_movePress;
    move -r -os -wd 0 10 0 ;
    AE_reselectTabIndex(4);
    $currentNode = startString($gAECurrentTab, 20);
    DLA_generateShadowMapsCreateAttr ($currentNode);
    DLA_shadowMapNameCreateAttr($currentNode);
    DLA_shadowMapResolutionCreateAttr($currentNode);
    DLA_shadowMapShadingRateCreateAttr($currentNode);
    DLA_shadowDepthFilterCreateAttr($currentNode);
    DLA_shadowMapTypeCreateAttr($currentNode);
    DLA_shadowMapPixelSamplesCreateAttr($currentNode);
    DLA_nearClipPlaneCreateAttr($currentNode);
    DLA_farClipPlaneCreateAttr($currentNode);
    DLA_emitPhotonsCreateAttr($currentNode);
    DLA_generateWithMotionBlurCreateAttr($currentNode);
    DLA_generateCubeShadowMapCreateAttr($currentNode);
    DLA_volumeInterpretationCreateAttr($currentNode);
    DLA_transformationBlurCreateAttr($currentNode);
    setAttr ($currentNode +".generateShadowMaps") 1;
    setAttr ($currentNode +".shadowMapType") 6;
    //lookThru `ls -sl`;
    person.py Temujin's Avatar
    Apr 2009
    Santa Monica, CA
    83
    Maybe try tossing in a refresh command? Seems like that AE reselect tab function does something in the UI which won't update until the script has finished.
    while loop btribble's Avatar
    Feb 2009
    SF Bay Area, US
    178
    I can't remember the solution to this. I think it may be that you need to put the latter part of your script in an evalDeferred or a ScriptJob "onIdle". So that the Attribute Editor has a chance to do it's update stuff. Also, the attribute editor needs to actually be open for this stuff to work. I assume that is a given.
