Thanks for the reminders
Removing the event.ignore()'s didn’t solve it, I have written a simplified script that reproduces my problem. It doesn’t have it’s own QApplication so copy and paste it in to Maya to try it out.
Alt + middleMouseClick is the combination used for panning.
import PySide.QtGui as QtG
import PySide.QtCore as QtC
import PySide.QtSvg as QtS
class MainWindow(QtG.QMainWindow):
def __init__(self, parent = None):
QtG.QMainWindow.__init__(self, parent)
self.initUI()
def initUI(self):
graphicsView = GraphicsView(self)
self.setCentralWidget(graphicsView)
self.setGeometry(100, 100, 800, 800)
self.show()
class GraphicsView(QtG.QGraphicsView):
def __init__(self, parent):
QtG.QGraphicsView.__init__(self, parent)
self.nodeEditorScene = GraphicsScene(self)
self.setScene(self.nodeEditorScene)
node01 = DrawNode(True)
self.nodeEditorScene.addItem(node01)
# This makes the node movable
node01.setFlag(QtG.QGraphicsItem.ItemIsMovable)
# Used for panning
self.mousePressPos = QtC.QPointF()
self.scrollBarValuesOnMousePress = QtC.QPointF()
self.alt = False
self.panning = False
# Commenting out the following mouse events will make the node movable and obviously disable panning
def mouseMoveEvent(self, event):
if self.panning and not self.mousePressPos.isNull():
self.horizontalScrollBar().setValue(self.scrollBarValuesOnMousePress.x() - event.pos().x() + self.mousePressPos.x())
self.verticalScrollBar().setValue(self.scrollBarValuesOnMousePress.y() - event.pos().y() + self.mousePressPos.y())
self.horizontalScrollBar().update()
self.verticalScrollBar().update()
event.accept()
def mousePressEvent(self, event):
# Panning
if event.button() == QtC.Qt.MidButton and self.alt and not self.panning:
print "mousePress ok!"
self.mousePressPos = QtC.QPointF(event.pos())
self.scrollBarValuesOnMousePress.setX(self.horizontalScrollBar().value())
self.scrollBarValuesOnMousePress.setY(self.verticalScrollBar().value())
self.panning = True
event.accept()
def mouseReleaseEvent(self, event):
if self.panning:
print "mouseRelease ok!"
event.accept()
def keyPressEvent(self, event):
if event.key() == QtC.Qt.Key_Alt:
print "keyPress ok!"
self.alt = True
event.accept()
def keyReleaseEvent(self, event):
print "keyRelease ok!"
self.alt = False
event.accept()
class GraphicsScene(QtG.QGraphicsScene):
QtG.QGraphicsScene.__init__(self, parent)
# Make the scene big to get some room for panning
self.setSceneRect(-10000, -10000, 20000, 20000)
class DrawNode(QtG.QGraphicsItem):
def __init__(self, AA = False, parent = None):
QtG.QGraphicsItem.__init__(self, parent)
self.newPos = QtC.QPointF()
self.setZValue(1)
self.penWidth = 1
self.hSize = 360
self.vSize = 400
# Specify the bounding box rectangle
self.qrectf = QtC.QRectF((-1 * (self.hSize / 2)) - self.penWidth / 2, (-1 * (self.vSize / 2)) - self.penWidth / 2, self.hSize + self.penWidth / 2, self.vSize + self.penWidth / 2)
# Just for debugging
print "mousePress event registered on the node itself!"
event.accept()
# Implements its pure virtual function boundingRect, to define the bounding box
def boundingRect(self):
return self.qrectf
# Implements its pure virtual function paint, to draw the item
def paint(self, painter, option, widget):
self.draw_nodeBackground(painter)
def draw_nodeBackground(self, painter):
QRectF_nodeBackground = self.qrectf
bgBrushColor = QtG.QColor(117, 117, 117, 255)
bgBrush = QtG.QBrush(bgBrushColor)
painter.setBrush(bgBrush)
painter.setPen(QtC.Qt.NoPen) #Don't draw the outline
painter.drawRoundedRect(QRectF_nodeBackground, 15, 15)
ex = MainWindow()
ex.show()
