All,
I wanted to post some instructions on how to get PyCharm auto-completing and remote debugging code with Maya 2013. Since everyone's work environment is slightly different, note that there's probably a few different ways to get this done. The following is how my stuff is currently set up:
Here's some images to go along with these instructions. At some point, I'll put these on my site in a more organized manner. Hope they help:Code:================================= PyCharm 2.6.2 Setup for Maya 2013 ================================= Prerequisites: -------------- * Your OS is windows 7 (Assumed to be x64) * Download and install PyCharm: http://www.jetbrains.com/pycharm/download/ * AutoDesk Maya is installed Instructions: ------------- 1. Create a symbolic link to mayapy.exe * Open a command prompt with admin rights: Start > All Programs > Accessories > right click on Command Prompt > Run as Administrator > Click [Yes] at UAC Dialog popup * Navigate to Maya's bin directory: cd "c:\Program Files\Autodesk\Maya2013\bin" * Make a symbolic link from mayapy.exe to python.exe (This essentially creates a renamed exe shortcut) You should see, "sybmolic link created for python.exe <<==>> mayapy.exe" if successful: mklink python.exe mayapy.exe 2. Configure PyCharm Maya Interpreter * Open PyCharm * Open the settings window File -> Settings... * Add our python.exe symlink as a python interpreter: * Navigate to Settings > Template Project Settings > Project Interpreter > Python Interpreter * click the [Add] button (plus icon) on the top far right * select "Local..." from the Select Interpreter Path dialog * select our "python.exe" symlink found at "C:\Program Files\Autodesk\Maya2013\bin\python.exe" from the selection dialog * hit the [OK] button and wait while PyCharm updates skeletons Leave this window up, don't close it! * Configure the Paths for our newly added interpreter: * With our newly added interpreter selected in the top pane, click on the _Paths_ tab in the bottom pane of the Python Interpreters window * Add path to AutoDesk provided stub files (This seemed to fix completion issues I was having): * Click the [Add] button (plus icon) on the top right of the _Paths_ pane * Navigate to and select "C:\Program Files\Autodesk\Maya2013\devkit\other\pymel\extras\completion\py" then click [OK] button * Remove Maya's site-packages entry (only if you added the stubs outlined above) * Select the entry for "C:\Program Files\Autodesk\Maya2013\Python\Lib\site-packages" * Click the [Remove] button (minus icon) * Add path Jetbrains Helpers (for remote debugging) * Click the [Add] button (plus icon) on the top right of the _Paths_ pane * Navigate to and select "C:\Program Files (x86)\JetBrains\PyCharm 2.6.2\helpers" then click [OK] button * OPTIONAL: Add any other sys paths you wish to incorporate here using same add steps as above * Close PyCharm and Reopen it for paths to take affect 3. Configure PyCharm Maya remote debugger * From the Run menu of PyCharm choose "Edit Configurations..." * Configure the Unnamed debugger which appears as follows: * Change Name field from "Unnamed" to "Maya 2013" (This value names the debugging process, feel free to choose any name) * Change port from "0" to "7720" (This number determines the port which traffics communication, feel free to use another port) * Check [x] Check no other instances are running * OPTIONAL: Uncheck [ ] Redirect output to console (to prevent output redirection from Maya) * OPTIONAL: Uncheck [ ] Suspend after connect (to only pause at a breakpoint) Note: settings in this window affect the code necessary to trip the remote debugger, displayed in sections 2 and 3. Be sure to write it down (or re-open this configuration window later to retrieve it later) 4. Remote Debugging from Maya * In PyCharm: * Select the "Maya 2013" Remote Debug profile from the Run/Debug dropdown just below the main menubar * Click the green debug icon next to the dropdown to start PyCharm's server * You will see a debug console appear below the main code window indicating the server is awaiting a connection * Load the code you wish to step through, and ensure there's a breakpoint set somewhere within the code * Paste the server configuration code from step 3's note into your code somewhere before your breakpoint and save the file. * In Maya: * Ensure that "C:\Program Files (x86)\JetBrains\PyCharm 2.6.2\helpers" is part of your sys.path (there are numerous ways to do this) pydev_path = r'C:\Program Files (x86)\JetBrains\PyCharm 2.6.2\helpers' if not pydev_path in sys.path: sys.path.append(pydev_path) * Import your and execute the code to remote debug. If all goes well, PyCharm should hold the code at your breakpoint, allowing you to navigate the code using the bottom Debugger pane
-csa
Bookmarks
