I have an odd issue while using Wing to debug in maya. So I am using pymongo to do some metrics tracking. The process of the problem is this:
[ol]
[li]Set breakpoint in wing[/li][li]Hit break point[/li][li]poke around[/li][li]continue[/li][li]Trigger the metrics function that stores an object to mongo[/li][li]the codecs module is set to None[/li][/ol]
At this point BSON freaks out and everything fails and i need to restart maya. If I never break, then all is well. The problem is in Maya/bin/python26.zip/encodings/utf_8.py. I i track it down there, it shows that the builtin codecs module has been set to None and thus cannot decode the string.
I’m not sure if this is wing specific or not, I figured I would throw it out here just in case.
Has anyone seen anything like this before?
