This post comes from my need to learn MaxScript in a pretty short amount of time. I am a long time user of both Mel and Python and so I don’t see it as being impossible to learn quickly.
What I am running into is an inability to grasp how Max accomplishes a lot of tasks. Even using something like the Macro recorder doesn’t yield all the information I need to know what Max is doing.
My example is in using a constraint. I want to script a position constraint. The first thing I do is actually create one to see what commands are thrown when the position constraint is used.
macros.run “Constraints” “Position_Constraint”
It returns this and then I select the 2 boxes and it snaps them together. The problem is I don’t what to use the interface tool to do it. I want my script to constrain two specified objects. Now i look for the command in the help docs.
constructor
Position_Constraint…
That is all the info I get. No flags or place to put the names of the objects I want to position constraint.
so That lengthy post is just to ask. Is there something I need to do to help me grasp how MaxScript works? How do I go about finding the information I need?
