send selected lines to maya
save following script as “send_to_maya.py”
pycharm external parameters setting >
[your path\send_to_maya.py] $FilePath$ $SelectionStartLine$ $SelectionEndLine$
#PyCharm python script by Yann Schmidt, https://github.com/justinfx/MayaSublime; Edited by Dontnoun(for trace back, error line number)
#Version: 1.0 Send whole file to Maya via commandPort and get trackback to pycharm (track back does not work for multi-process-thread function)
#copy below 5 lines to your ..\Users\[user name]\Documents\maya\[maya_version]\scripts\userSetup.py(remove first '#' symbol for each line)
#import maya.cmds as cmds
#try : cmds.commandPort(n='127.0.0.1:7001' , bs=128000, stp = 'mel')
#except : pass
#try : cmds.commandPort(n='127.0.0.1:7002' , bs=128000, stp = 'python')
#except : pass
import sys, os, textwrap, time
from telnetlib import Telnet
class SendToMaya(object):
PY_CMD_TEMPLATE = textwrap.dedent('''
import traceback
import __main__
namespace = __main__.__dict__.get('_pycharm_SendToMaya_command')
if not namespace:
namespace = __main__.__dict__.copy()
__main__.__dict__['_pycharm_SendToMaya_command'] = namespace
namespace['__file__'] = {2!r}
try : {0}({1!r}, namespace, namespace)
except : traceback.print_exc() ''')
def __init__(self):
self.maya_log_pth = os.path.dirname(os.path.abspath(__file__)).replace('\\','/') + '/'
self.execType = 'execfile'
self.fileType = 'python'
slins_buf_py_pth = self.maya_log_pth + 'slins_buff.py'
with open(str(sys.argv[1]), 'r') as slin_id :
slines = slin_id.readlines()[ int(sys.argv[2])-1: int(sys.argv[3]) ]
with open(slins_buf_py_pth, 'w+') as wslns_id :
for ww in slines : wslns_id.write(ww)
self.file = slins_buf_py_pth #str(sys.argv[1])
self.sep = None
self.is_python()
self._settings = dict()
self.init_settings()
def init_settings(self):
maya_hostname = "127.0.0.1" #-------------!!!
python_command_port = 7002 #-------------!!!
mel_command_port = 7001 #-------------!!!
self._settings['host'] = maya_hostname
if self.fileType == 'python':
self._settings['port'] = python_command_port
self.sep = '
self._settings['port'] = mel_command_port
self.sep = '\r'
def is_python(self):
if sys.argv[1].endswith('.py'): self.fileType = 'python'
elif sys.argv[1].endswith('.mel'): self.fileType = 'mel'
else: self.fileType = None
def run(self):
maya_log_pth = self.maya_log_pth + 'pycharmya.log'
with open(maya_log_pth, 'w+') as empty_id : empty_id.write('')
buff_pym_pth = self.maya_log_pth + 'maya_2pycharm_buf.fer'
if self.fileType is None:
print("No Maya-Recognized language found.")
return
#----------------------#----------------------VVV to get maya track back and debug line
crnt_py_line_lst = []
with open(self.file, 'r') as crnt_fid :
for cc in crnt_fid.readlines() :
crnt_py_line_lst.append(cc.strip('
if self.fileType == 'python' :
pre_cmd = "import maya.cmds as cmds; mlg = '" + self.maya_log_pth + "pycharmya.log'; cmds.scriptEditorInfo(hfn = mlg, wh=1);print 'MaYa Track Back :\
pst_cmd = "import maya.cmds as cmds; cmds.scriptEditorInfo(hfn = mlg, wh=0)"
mrk_cmd = "with open('" + self.maya_log_pth + "maya_2pycharm_buf.fer', 'w+') as bfd : bfd.write('xxx')"
with open(buff_pym_pth, 'w+') as buff_fid :
buff_fid.write(pre_cmd + '
buff_fid.write('import sys, traceback
try :
for bb in crnt_py_line_lst : buff_fid.write(' ' + bb + '
buff_fid.write('except Exception as eRr :
for x in traceback.extract_tb(sys.exc_info()[2]):print type(eRr), eRr.args[0], "\
", "Error on line:", x[1]-3, "--> ", x[3], "\
buff_fid.write(pst_cmd + '
' + mrk_cmd + '
else : buff_pym_pth = self.file #-----for mel
#----------------------#----------------------AAA to get maya track back and debug line
snips = []
if self.fileType == 'python': snips.append(buff_pym_pth)
else: snips.append('rehash; source "{0}";'.format(buff_pym_pth))
mCmd = str(self.sep.join(snips))
if not mCmd : return
if self.fileType == 'python': mCmd = self.PY_CMD_TEMPLATE.format(self.execType, mCmd, buff_pym_pth)
if self.fileType == 'mel': mCmd = mCmd.replace('\\', '/')
tnt = None
tnt = Telnet( self._settings.get('host'), int(self._settings.get('port')), timeout=3 )
tnt.write(mCmd.encode(encoding='UTF-8'))
if self.fileType == 'python' : self.get_maya_trackback() #-------------!!! track back only for python not mel
except Exception:
err = str( sys.exc_info()[1] )
print("Failed to communicate with Maya (%(host)s:%(port)s)):
%(err)s" % locals())
raise
else: time.sleep(.1)
finally:
if tnt is not None: tnt.close()
def get_maya_trackback(self):
while 1 :
time.sleep(0.3) #-------------!!!
with open(buff_pym_pth, 'r') as buf_id :
mrk_str = buf_id.readline().strip('
with open(maya_log_pth, 'r') as crash_id :
crash_str = crash_id.readline().strip('
if crash_str is not None and crash_str != 'MaYa Track Back :' :
print 'Fatal SyntaxError: Can not run in MaYa!'
break
if mrk_str == 'xxx': #-------------!!!
with open(maya_log_pth,'r') as mlog_id :
for ii in mlog_id.readlines():
print ii.strip('
break
snd = SendToMaya()
snd.run()
#-----------------------------------------------old version
when I move maya python IDE to Pycharm, got a problem, pycharm can not get track back and error info from maya,
searched in google ,found something :
http://tech-artists.org/forum/showth...5280-MayaCharm
unfortunately it does not work for my computer…
maybe difference maya, pycharm version or os platform caused problem
then found a script from this page,
http://www.yannschmidt.com/blog/crea...mmand-pycharm/
its pretty good, I edited the script to get maya track back and error line info
it is a simple python script, should work in many versions of maya and pycharm and os
edited script is here:
#PyCharm python script by Yann Schmidt, https://github.com/justinfx/MayaSublime; Edited by Dontnoun(for track back, error line number)
#copy below 5 lines to your …\Users[user name]\Documents\maya[maya_version]\scripts\userSetup.py(remove first ‘#’ symbol for each line)
#try : cmds.commandPort(n=‘127.0.0.1:7001’ , bs=128000, stp = ‘mel’)
#except : pass
#try : cmds.commandPort(n=‘127.0.0.1:7002’ , bs=128000, stp = ‘python’)
#except : pass
PY_CMD_TEMPLATE = textwrap.dedent(’’’
import traceback
import main
namespace = main.dict.get(’_pycharm_SendToMaya_command’)
if not namespace:
namespace = main.dict.copy()
main.dict[’_pycharm_SendToMaya_command’] = namespace
namespace[‘file’] = {2!r}
except : traceback.print_exc() ‘’’)
def __init__(self):
self.file = str(sys.argv[1])
self.sep = None
self.is_python()
self.sep = '
self._settings[‘port’] = mel_command_port
self.sep = ‘\r’
def run(self):
return
pst_cmd = “import maya.cmds as cmds; cmds.scriptEditorInfo(hfn = mlg, wh=0)”
mrk_cmd = “with open(’” + self.maya_log_pth + “maya_2pycharm_buf.fer’, ‘w+’) as bfd : bfd.write(‘xxx’)”
with open(buff_pym_pth, ‘w+’) as buff_fid :
buff_fid.write(pre_cmd + ’
try :
for bb in crnt_py_line_lst : buff_fid.write(’ ’ + bb + ’
", “Error on line:”, x[1]-3, "–> ", x[3], "
buff_fid.write(pst_cmd + ’
’ + mrk_cmd + ’
snips = []
tnt = None
except Exception:
raise
finally:
if tnt is not None:
tnt.close()
while 1 :
time.sleep(0.2) #-------------!!!
with open(maya_log_pth, ‘r’) as crash_id :
crash_str = crash_id.readline().strip(’
if crash_str is not None and crash_str != ‘MaYa Track Back :’ :
print ‘Fatal SyntaxError: Can not run in MaYa!’
break
if mrk_str == ‘xxx’: #-------------!!!
with open(maya_log_pth,‘r’) as mlog_id :
print ii.strip(’
break
snd = SendToMaya()
snd.run()
