I’ve set up hotkeys for selecting verts, edges and faces. However, I would really like a hotkey to select border edges the same way you do in 3dsMax. It doesn’t seem there is a selection tool in Maya that can do this on the fly, I always have to double-click an edge in edge-selection mode.
I basicly want to press the hotkey (which emulates a new selection mode), so whenever I drag-select over a mesh it will only select the border edges. If I were to select one edge that happens to be a border edge, it should select the entire loop.
So I was wondering, do anyone know if this is achievable in Maya? As you can direct hotkeys to run a script I’m guessing it could be possible, but the way I want this to work makes it challenging to create a script that does this for me.
