Results 1 to 11 of 11
Thread: using maya api getPoints() method
    variable
    Feb 2016
    20
    Default using maya api getPoints() method
    Hi there,
    i basically have two different shaped meshes with identical topology. I want to be able to getPoints from one mesh and setPoints onto the other mesh. The code im using the getPoints however doesn't seem to store anything. Can someone show me where im going wrong?
    def getPoints(geo):
        sel = om.MSelectionList()
        dag = om.MDagPath()
        sel.add(geo)
        sel.getDagPath(0,dag)
        mesh = om.MFnMesh(dag)
        vts=om.MPointArray()
        mesh.getPoints(vts, om.MSpace.kObject)
    thanks
    Sam x
    struct
    Mar 2011
    San Francisco
    348
    Your code is correct. vts will be an MPointArray filled with the points of your mesh. What issue are you running into?
    import maya.OpenMaya as om
    def getPoints(geo):
        dag = om.MDagPath()
        sel.add(geo)
        return vts
    cube = cmds.polyCube(ch=False)[0]
    pts = getPoints(cube)
    for i in range(pts.length()):
        print i, pts[i].x, pts[i].y, pts[i].z
    0 -0.5 -0.5 0.5
    1 0.5 -0.5 0.5
    2 -0.5 0.5 0.5
    3 0.5 0.5 0.5
    4 -0.5 0.5 -0.5
    5 0.5 0.5 -0.5
    6 -0.5 -0.5 -0.5
    7 0.5 -0.5 -0.5
    program Theodox's Avatar
    Mar 2012
    Seattle
    1,107
    May be relevant if things seem puzzling:
    http://techartsurvival.blogspot.com/...getpoints.html
  4. #4
    Mar 2012
    Seattle
    1,107
    Correction - that link is for api2, it looks like your code is api 1. The Capper has it.
  5. #5
    variable
    Feb 2016
    20
    ok thanks guys.
    sorry, i guess the problem i am having is a separate part of the script i didnt mention, which gets the verts of two meshes and tries to add them together, it says 'zip argument #1 must support iteration '
    def addVerts(scan1_verts, scan2_verts):
        add_list=om.MFloatPointArray()
        for (v1,v2) in zip(scan1_verts,scan2_verts):
            p1=om.MFloatPoint(*v1)
            p2=om.MFloatPoint(*v2)
            add_list.append(om.MFloatPoint(p1+p2))
    and then after this, add_list is what i want to use when i want set the points onto another mesh
    Maybe i need to get the mesh points a different way and append one by one to a list?
    thanks,
    Sam
  6. #6
    while loop
    Feb 2010
    171
    What type of values are scan1_verts and scan2_verts? Are those both MFloatPointArrays?
    Because I'm fairly certain that you can't use zip with MFloatPointArrays. Just something with how the swig wrapper was setup.
    Might try this instead:
        for i in xrange(scan1_verts.length()):
            p1 = scan1_verts[i]
            p2 = scan2_verts[i]
  7. #7
    Mar 2012
    Seattle
    1,107
    I think Bob has it -- I don't believe that api 1 PointArray classes are complete python iterables.
  8. #8
    while loop
    Feb 2010
    171
    Oh, fun fact, if you call:
    list(om.MFloatPointArray())
    You'll kick off an infinite loop + memory leak that will do bad things to your computer. So yeah, don't do that to test whether the class is a proper itertable or not...
  9. #9
    Mar 2012
    Seattle
    1,107
    FWIW I'd look at moving the whole thing over to api 2 - where the arrays act like proper iterables. In general api 2 is faster and easier to use.
  10. #10
    while loop
    Feb 2010
    171
    Quote Originally Posted by Theodox View Post
    Agreed.
  11. #11
    variable
    Feb 2016
    20
    cool thanks guys. I find all this quite overwhelming so i dont think i can try and convert everything to API2 just yet. But i have got it all working with the information you've told me, thanks
