Results 1 to 4 of 4
Thread: [Maya][Python] Tools Question -> 3D pipeline example tools
  1. #1
    integer PereBalsach's Avatar
    Join Date
    Apr 2015
    Location
    Barcelona
    Posts
    33
    Default [Maya][Python] Tools Question -> 3D pipeline example tools
    Hi!
    I want to learn more python and do some side projects at home.
    So, I was wondering If anyone could tell me, apart form an asset manager, the most common tool for a 3D pipeline for games.
    Or some useful tool I could write.
    So, I would be very grateful is some of you guys could point me some examples of tools I could write.
    Thank you so much in advice ^_^
    Cheers!
  2. #2
    integer
    Join Date
    Mar 2009
    Location
    Japan, Tokyo
    Posts
    49
    Default
    Well the base pipeline when you work as TechArt in a 3D team is :
    1 - Set Project interface to keep project clean and relative path for texture, etc...
    2 - Export tool (one click export to game project) (static mesh, skeleton, animation, etc...)
    After it is more about team request & need... depending of projects, etc...
  3. #3
    program Theodox's Avatar
    Join Date
    Mar 2012
    Location
    Seattle
    Posts
    1,107
    Default
    A great starter project is a window which runs a series of scene checks (things like "no degenerate faces" or "all objects have an assigned material"). Besides learning how to do the actual checks in Python you can learn a good deal about how to organize the code and make it modular -- you'd like to be able to add to the list of checks and run them without re-writing the whole thing... There was a discussion thread on the tech-artists.slack.com a week ago or so, it has probably not scrolled off yet.
  4. #4
    while loop
    Join Date
    Feb 2010
    Posts
    179
    Default
    If you're not in the slack channel itself (you should join, its great).
    http://tech-artists.slackarchive.io/...193412.000799/
    The topic was on the 6th, so you'll have to scroll down. Also the archive is annoying because it is in reverse. Haven't really figured out a good way around that problem yet.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
