Results 1 to 6 of 6
Thread: copying skin weights from one mesh to another
  1. #1
    variable
    Join Date
    Feb 2016
    Posts
    20
    Default copying skin weights from one mesh to another
    Hello,
    this maybe a simple one. But i couldn't find exactly the answer i was looking for elsewhere.
    I basically have to identical meshes both smooth bound with identical skeletons, one has painted skin weights. The only difference is the joint names/numberings dont match, but the hierarchies are exactly the same.
    i was wondering if anyone knew a way to copy over the skin weights to the other mesh when the joint numbers need to be matching.
    thanks,
    Sam
  2. #2
    /? eevans's Avatar
    Join Date
    Aug 2008
    Location
    Atlanta, GA
    Posts
    151
    Default
    If you're using 3DS Max, you could simply export out an env file from the source skin modifier, and then load this env file unto the skin modifier of the target mesh. The "Load Envelopes" dialog should match bones by index (skin modifier index) by default. I believe the vert IDs of the two meshes in question would need to line up for this method to work. If your vert IDs have change, try the above process with the "Load Vertices By Index" checkbox unchecked.
    On the other hand if bone hierarchy is the only method you have to match bones between the two meshes and you want to automate the process of bone re-mapping, you'll likely have to come up with a custom solution using MAXScript etc.
    Otherwise, I believe that both the env load dialog and the Skin Utilities tool allow you to manually re-map bones.
    Eric N. Evans
    Sr. Technical Artist
    Hi-Rez Studios
    http://www.ericnevans.com
  3. #3
    variable
    Join Date
    Feb 2016
    Posts
    20
    Default
    oops, sorry i forgot to mention, im using maya 2017. maybe similar problem though?
    Sam
  4. #4
    Default
    Is there any reason why you couldn't just rename the identical skeleton to match what you want to copy from? Even if you did this temporarily?
    If you do then you could just use my "skinTo" function from here: http://pastebin.com/ak3xunEQ
  5. #5
    Default
    Oh just select the source mesh, then shift select target mesh and go to Skin > Copy Skin Weights :)
  6. #6
    undefined sscott's Avatar
    Join Date
    Aug 2013
    Location
    Cambridge - Nottingham
    Posts
    2
    Default
    Personally i use ngSkinTools now for pretty much all my skinning in Maya. I cant recommend it enough.
    Its got a very robust Skin load and save system using Json files. (It also allows remapping to different joint names on the skeleton.)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
