Calling Python scripts from Maya MEL menuItem
Hey Guys,
I have a problem with passing MEL variables to a Python script from a MEL script.
this works:
menuItem -l “mirror ctrl” -c “python(“import Mirror;Mirror.mirror()”)”;
Then I try to pass the $object variable and the number 1 to the script and I get syntax error:
menuItem -l “mirror ctrl” -c “python(“import Mirror;Mirror.mirror(””+$object+"", 1)")";
Any ideas?
I am creating a dropdown menu when you right click a control on a rig, I have to use MEL because I am making changes in the dagMenuProc.mel script.
Cheers!
Try putting parentheses around the command string, to make sure the whole thing gets parsed as a single entity:
menuItem -l "mirror ctrl" -c ("python(\"import Mirror;Mirror.mirror(\""+$object+"\", 1)\")");
Thanks, It runs the script and it gets the MEL variable now but it still gives a syntax error.
// Error: python(“import Mirror;Mirror.mirror(“armL”, 1)”); //
// Error: Line 1.51: Syntax error //
fixed it :D, this works!
menuItem -l “mirror ctrl” -c (“python(“import Mirror;Mirror.mirror(’”+$object+”’, 1)")");
