Smooth Mesh preview
So here is the problem : I want to link smooth mesh previews of two objects so
that when I hit ‘3’ both become smooth without selecting the two , but one (that would be the one that drives the smooth preview)
Now the real thing is I have no Idea how to do it , I though first I could do some attributes connection and shit , but no, because the
Smooth Mesh Attribute doesn’t exist on the mesh node, you have Smooth Level attribute tho , but that’s 1% of the problem.
Solutions?
from the maya script :
// Result: Mel procedure found in: PATH/autodesk/maya20XX/scripts/AETemplates/AEmeshTemplate.mel //
I found that displaySmoothMesh is the name of the Attr. But anyway you can’t connectAttr something on it.
You may have to create a scriptjob for this or bind the ‘3’ button with a custom script that check dependencies object (like a custom attr)
smpMode = cmds.getAttr(‘pCubeShape1’ + “.displaySmoothMesh”)
smpMode = cmds.setAttr(‘pCubeShape1’ + “.displaySmoothMesh”, 2)
@“AbsurdityDW” , Yep I though about scriptJob, but I didn’t want to go there… Guess I’ll have to
