Results 1 to 1 of 1
Thread: Count, filter out duplicates for dictionaries
    Default Count, filter out duplicates for dictionaries
    I have an iterator in which it returns me the following - item_name, item_size, user_name
    What is the best way in which I can use if I wanted to:
    • Collate similar item_namings into a 1-liner
    • Prior to point #1, calculate the number of items
    • Prior to point #1, it will also displays the user_names affiliated with the versions and the size it used in descending order
    Currently I am using a lot of dictionaries and I am not sure what is the best way to approach this..
    gen_dict = {}
    size_dict = {}
    # my_iterator is the one that I have mentioned as above
    for result in my_iterator:
        gen_dict[result['object_name']] = result['user']
        size_dict[result['user]] = result['dir_size']
       # If same key exists, append value to existing key
       if result['owner'] in size_dict:
           size_dict[result['owner']].append(result['dir_size'])
    # Filter out duplicates, count versions
    asset_user_dict = defaultdict(set)
    asset_count = defaultdict(int)
    user_ver_count = defaultdict(lambda: defaultdict(int))
    for vers_name, artist_alias in ivy_results.iteritems():
        strip_version_name = vers_name[:-3]
           asset_user_dict[strip_version_name].add(artist_alias)
           asset_count[strip_version_name] += 1
           user_ver_count[artist_alias][strip_version_name] += 1
    # Gather the sum of all item's size accordingly to each user
    for user_name, user_size in size_dict.iteritems():
        # This will sums up all sizes of that particular user
        size_dict[stalk_name] = sum(user_size)
    for version_name, version_count in sorted(asset_count.iteritems()):
        user_vers_cnt = ', '.join('{0}({1}v, {2})'.format(user, user_ver_count[user][version_name], convert_size_query(ivy_size_query[user])) for user in asset_user_dict[version_name])
        print "| {0:<100} | {1:>12} | {2:>90} |".format(version_name+"(xxx)",
        version_count,
        user_vers_cnt
    I tried using dictionary but while I can do almost all the above 3 points, I am having issues with point #3 where I either can't seem to sort them in order or the size dervied for the user are of the same value as I am using multi dictionaries? Any advice is greatly appreciated!
    By the way, my output currently is:
    Suppose if my data is something like
    (1 MiB) "item_C_v001" : "jack"
    (5 MiB) "item_C_v002" : "kris"
    (1 MiB) "item_A_v003" : "john",
    (1 MiB) "item_B_v006" : "peter",
    (2 MiB) "item_A_v005" : "john",
    (1 MiB) "item_A_v004" : "dave"
    Item Name     | No. of Vers.      | User
    item_A           | 3                     | dave(1, 1MiB), john(2, 3MiB)
    item_B           | 1                     | peter(1, 1MiB)
    item_C           | 2                     | kris(1, 5MiB), jack(1, 1MiB)
