Results 1 to 6 of 6
Thread: Shelf no loading correctly in Maya 2016
  1. #1
    variable
    Join Date
    Nov 2016
    Posts
    26
    Default Shelf no loading correctly in Maya 2016
    Hey guys, I know this is not a support website but I am having an issue with loading shelf icons (Scripts) onto a few artists Maya shelves. I am placing the Shelf.mel in their 'C:\Users\Artist\Documents\maya\2016\prefs\shelves ' and the shelf itself loads into Maya, but it's not creating the icons, and I am able to call the commands from the script editor so I know it's not an issue with the code.
    Has anyone experienced this? or have any idea of what I should do? I have already deleted their userPrefs.mel and tried a few other things to no luck. It's also happening on random machines, with the exact same systems. They can't even create and save their own shelves.
  2. #2
    Technical Artist
    Join Date
    Jul 2008
    Location
    Austin, TX
    Posts
    677
    Default
    i have seen this before, i will need to bang my head against the wall for a bit to remember what caused it...
    i vaguely remember that I had phantom shelves saved into my userPrefs.mel file, I scrubbed through the optionVars for each shelf and verified they were correct.
    I also vaguely remember the XGen shelf was involved somehow, either as part of the problem or exhibiting symptoms.
  3. #3
    variable
    Join Date
    Nov 2016
    Posts
    26
    Default
    Quote Originally Posted by rgkovach123 View Post
    Deleting the XGEN worked!!!! THANK YOU!!!!1
  4. #4
    while loop
    Join Date
    Feb 2010
    Posts
    183
    Default
    Yeah, the XGen shelf seem to be generated weirdly, it's caused all kind of weird phantom issues for me in the past.
  5. #5
    Technical Artist
    Join Date
    Jul 2008
    Location
    Austin, TX
    Posts
    677
    Default
    yay! now i need to make a note just in case it happens again...
  6. #6
    while loop
    Join Date
    Feb 2010
    Posts
    183
    Default
    I found that if I iterated through all the active shelves before making any changes to the shelves themselves, that I could avoid it's weirdness.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
