Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 114
Thread: Useful "outside" tools
  1. #41
    Default
    Here's my contribution:
    - Scope : I use it mainly to read .tga sequences, it's fast and very light. It has a few bugs, the most notorious one being playing the sequences at the wrong FPS but you can solve this by disabling Background Cache.
    - Media Player Classic : Couldn't let this one out :D
  2. #42
    Default
    Quote Originally Posted by Kameleon View Post
    This looks interesting.
    Another option is DJV
  3. #43
    Default
    Quote Originally Posted by ofer_z View Post
    Yeah, I remember using that one, but it lacks direct support for network, although if you write down the path it works... I'll give it a try again.
  4. #44
    Default
    You can always simply drag a file onto it, that's what I usually do.
  5. #45
    Administrator Rob Galanakis's Avatar
    Join Date
    Jun 2008
    Location
    Reykjavik, Iceland
    Posts
    1,242
    Default
    Check out MEncoder, a command line video compression tool.
    http://www.mplayerhq.hu/design7/news.html
    I am using it to auto-compress some uncompressed AVI's I am auto-rendering/compositing from Max, it works really great and is very well documented (only about a half hour of hair pulling before I figured it out).
    Forum Administrator
    www.robg3d.com
  6. #46
    untitled
    Join Date
    Jul 2008
    Location
    Philadelphia, Pa
    Posts
    59
    Default
    I'll add in TreeSize Free from Jam Software as an easy way to see what directories are what sizes.. (The Pro version is actually *QUITE* nice also for those who find themselves keeper of the network.)
    TodoList from www.abstractspoon.com an open source and generally badass task manager
    I'll throw another vote out there for Pstools and all of the sysinternals tools. I use them daily as a part of this monstrosity: Slave Utils for easy access to some basic tasks on our farm.
    Also use Dropbox non stop for easy syncing of a few files between work/home. Its still in a closed beta, but sign up, they're adding people non stop.
    That and the service at LogMeIn a web based VNC on steroids. great for the 'shit i forgot to ___________' moments when I don't want to drive back to work :)
  7. #47
    Project Manager
    Join Date
    Aug 2008
    Location
    Chicago
    Posts
    21
    Default
    As I mentioned in the ATI vs nVidia thread, I am going to have to recomemnd Rivatuner
    For nVidia users, Rivatuner grants an extreme amount of control over your video hardware. You can monitor GPU temperature, monitor and set fan speed, overclock or detune the GPU and shader clocks, and then create performance profiles that can be launched manually or triggered according to some set of conditions. There's a ton of other stuff in there too, but what I listed is what i use it for.
    I have a pair of LE 8800GTXs running in SLi, which can run really hot depending on what I am doing. I used Rivatuner to monitor the GPU temperature and fan speed in the windows task bar, and also created a couple of performance profiles that detune the cards and crank the fans up when the temp reaches a certain threshold. Now I run hitch free.
    One word of advice: If you update your drivers past the version that Rivatuner supports, your performance profiles may report being invalid and get cleared, though they still seemed to work in my particular case once I had recreated them. now I just wait for Rivatuner updates.
  8. #48
    variable
    Join Date
    Jul 2008
    Location
    Austin
    Posts
    16
    Default
    Didn't see this one yet.
    Oscar's File Renamer
    File renamer that works like a text editor, complete with macros. Hit a accept button and files are renamed.
  9. #49
    string
    Join Date
    Jul 2008
    Location
    Helsinki, Finland
    Posts
    101
    Default
    FileLocator Pro. It just does a brute force search for any files for any strings. Finally a search in Windows that just works. Every time.
    Araxis Merge. Can't imagine living without it. I use it pretty much for diffing any kind of content.
    SamiV.
  10. #50
    Default
    Quote Originally Posted by Dave Buchhofer View Post
    Really like that one! Thanks!
  11. #51
    while loop
    Join Date
    Jul 2008
    Location
    Boston USA
    Posts
    172
    Default
    JReplace, a Java OS-agnostic "search & replace utility that searches and replaces multi-line text in files in a directory or subdirectories." I like how super-simple it is. Works on all ASCII filetypes.
  12. #52
    Technisch Geschäftführer
    Join Date
    Aug 2008
    Location
    Prague
    Posts
    71
    Default
    I'll be pretty obvious, but misc tools that I simply couldn't live/work without are:
    Total Commander
    FrameCycler Pro
    SciTE
    WinAmp
    XnView
    Rainlendar
    Character Map
    Calc
    and of course
    FireFox
    - loocas
    webSite | blog
  13. #53
    undefined
    Join Date
    Oct 2008
    Location
    NRW Germany
    Posts
    3
    Default
    PFrank
    awesome tool for replacing any kind of strings, xtensions, etc for folders, i use it alot. Multiple search pattern can be adjusted, well worth a look.
    ConTEXT
    my favorite text editor (mel language can be downloaded seperatly)
    Totalcommander
    for sure
    Date Edit
    http://www.brothersoft.com/ninotech-date-edit-7682.html
    pretty handy for editing dates, simply open the Windows Explorer, right-click the file(s) of interest and choose Edit Date from the context.
  14. #54
    Int64
    Join Date
    Nov 2008
    Location
    Vienna, Austria
    Posts
    61
    Default
    so, as first-time poster let me say hello and add my list of usefool tools:
    WAssociate:
    edit file-extension associations/menus/defaultactions in one place
    http://www.xs4all.nl/~wstudios/Associate/index.html
    NirSoft:
    similar to Sysinternals, but i think even more tools, and different
    http://www.nirsoft.net/
    File-Ex:
    Filedialog auto-resizing,auto-centering, configureable view, file/folder history etc...
    can't live without this, costs a few bugs and is a bit old already but again can't live without
    http://www.cottonwoodsw.com/fx3summ.html
    Screenshots to get an idea:
    http://www.cottonwoodsw.com/fx3pics.html
    TrueLaunchbar:
    forget the windows start menu and make your taskbar a better and organized launcher...
    a lot plugins can give you gimmicks ( i do not use), but by default it's very slim and has small foodprint
    http://www.truelaunchbar.com/
    Erunt & Regopt:
    Very small Registry Backup/restore tool with optimization option.
    Backup your Registry once every few days and you don't have to reinstall Windows+Drivers+Software, after virus/buggy driver install or defective registry files
    http://www.larshederer.homepage.t-online.de/erunt/
    Hashtab:
    If you got to deal with CRC/SHA/MD5 or whatever hashvalues, adds hash tab in explorers properties
    http://beeblebrox.org/hashtab/
  15. #55
    Seb sebddd's Avatar
    Join Date
    Aug 2008
    Location
    London
    Posts
    41
    Default
    By adding tons and tons of tools to gain additional tricky helpful bits and the like at some point your machine might end up in an amazing stack of layers of .... "STUFF" lol
    So I just thought about :
    http://technet.microsoft.com/en-us/s...s/default.aspx
    The magic wands from Mark Russinovich.
    One day or another you'll unavoidably have to download one of these to actually know what's going on in your PC.
  16. #56
    Roger Klado
    Join Date
    Oct 2008
    Location
    Austin/Baltimoron
    Posts
    57
    Default mapy
    Maya .mel .py + Mapy + Textpad
    new version was jes released
    output and input. execute from any text editor to and from Maya.
    Not at the mercy of a plug-in compile fer yer version.
    http://rodmena.com/mapy/
    werkin' great with Textpad
  17. #57
    Administrator Butters's Avatar
    Join Date
    Aug 2008
    Location
    Vancouver, Canada
    Posts
    250
    Default
    TeraCopy!
    this is an awesome copy interface:
    http://www.codesector.com/teracopy.php
    • Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce seek times. Asynchronous copy speeds up file transfer between two physical hard drives.
    • Pause and resume file transfers. Pause copy process at any time to free up system resources and continue with a single click.
    • Error recovery. In case of copy error, TeraCopy will try several times and in the worse case just skips the file, not terminating the entire transfer.
    • Interactive file list. TeraCopy shows failed file transfers and lets you fix the problem and recopy only problem files.
    • Shell integration. TeraCopy can completely replace Explorer copy and move functions, allowing you work with files as usual.
    • Full Unicode support.
    Pro version is even better.
    ~B)
  18. #58
    Int64
    Join Date
    Nov 2008
    Location
    Vienna, Austria
    Posts
    61
    Default
    ha - DrBob
    that thing reminds me of another GREAT copy tool ( command line though )
    xxcopy - http://www.xxcopy.com/index.htm
    great tool to clone whole foldertrees/drive contents, including security and file/folder compression. Lot of options good performance etc....
    Freeware and Pro Editions available....
  19. #59
    Default
    http://www.dvdvideosoft.com/
    All sorts of media conversion apps here. I find myself using these more and more. They are easy to use, fast, and free!
  20. #60
    Lead & Technical Artist
    Join Date
    Dec 2008
    Location
    Australia
    Posts
    14
    Default
    I think just about everything I use has been covered.
    The only other additions I can think of are:
    Sequoia View It's a great app for visualising where all your drive space has gone.
    Edit Plus is my text editor of choice, It does all the usual goodies like text highlighting, macros, bracket matching etc.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
