Adding methods dynamically to MObject in python
coding
python
maya
Hey there,
We’ve written a few classes to serialize various objects, one way we’re thinking of handling this is by adding a ‘special’ method to the classes we want to write out.
We’ve managed to do this with motionbuilder thanks to python’s flexibility, however we’re unable to add methods to any maya.api.OpenMaya classes:
def my_method(self):
    return 'my_method'
maya.api.OpenMaya.MObject.my_method = my_method
# Error: TypeError: file <maya console> line 1: can't set attributes of built-in/extension type 'OpenMaya.MObject' #
This is the case for almost all maya.api classes. Has anyone gotten around this?
#2
As it says, you can’t actually add methods to builtin objects, so there isn’t really a way to add them.
These objects were defined in C and as such lack much of flexibility you’d get from a python defined object.
You could always create a subclass that holds your extra methods.
Or instead just create them as functions where you pass the objects in explicitly.
#3
Thanks for the confirmation.
