Calling UI objects
qt
python
maya
I am currently writing a ui script for Maya in python.
It goes something like this
def loadUI():
    #loads UI
def getMayaWindow():
    #gets the maya main window
class MainClass():
    def __init__ (self, parent = getMayaWindow()):
    #initialise
        super(MainClass, self).__init__(parent)
        self.setupUi(self)
    #create connections to ui
    self.QComboBox.addItems([1,2,3,4])
    self.deleteButton.clicked.connect(self.delete)
def delete(self):
    self.deselect = self.QListWidget.selectedItems()
    for j in self.deselect:
        self.QListWidget.takeItem(self.QListWidget.row(j))
so, I have ui that has different tabs at the top and I do not want to put every single piece of code in the MainClass because that would be too messy and long. For every tab, I want to write its script in a different .py file. I want to create the connections under the init function, at the same time, load functions from another script into this MainClass to be used.
Question is, how should I go about calling objectName from the ui in a new file? I tried to import the MainClass code but that didn’t work and I don’t want the initialize the ui window in the new .py file. What’s a good way to go about this?
Thanks
#2
So I’m not sure exactly what you’re asking. But I think you’re hoping to have a window/dialog with a tabbed layout, and you want each tab to be defined in it’s own separate python file?
So this example https://pythonspot.com/en/pyqt5-tabs/ show just how to setup some basic QWidgets in a tabbed layout.
If you replace those widgets with you’re own custom widgets, you should be able to do what you’re looking for.
Unless I’ve misunderstood completely.
#3
Your question is not very clear.
What I understand here is that you want to separate each tab content in a different .py file.
In your MainClass you can create your UI, and then create a TabLayout as @R.White said.
Then you can import all those UI .py files, calling a function on each of them that receives the tabLayout and add a tab with contents to it.
   import uiTab1
   import uiTab2
   import uiTab3
   CreationFunction():
        //Create Ui stuff...
        //Create a tab layout
        uiTab1.create(tabLayout)
        uiTab2.create(tabLayout)
Each file would be:
uiTab1.py
 def create(QTabLayout lyt):
       ///create other UI related to this tab.
       lyt.addWidget()....
Hopefully you meant that. I can fix my answer if it wasn’t what you were asking!
