I am doing a bit of Photoshop scripting. The code is getting to be a bit longer than I would like to keep in a single file and there is a lot here I would like to use in other scripts. Is it possible to do a python style include to help break this up?
Yup,
I think you can do something like this:
#include “ReferenceToOtherFile.jsx”;
[QUOTE=shane;26546]Yup,
#include “ReferenceToOtherFile.jsx”;[/QUOTE]
Thanks!
check this as well, it will give you a “require” function that is more similar to an import:
var ui = require('lib.ui');
var win = ui.MyWindow();
Include works, also a other trick is to Rename your included jsx files to jsxinc that way you can still include them but photoshop won’t add them to the scripts menu.
I do that in one of my tools https://github.com/cmcpasserby/psMaskSync/tree/master/psMaskSync
