Hello there.
I am having difficulty trying to get value from attribute from certain frame. For example, I want to always get value from object.tx at frame 1.
I tried to use frameCache node, but it query attribute relative to the current frame and you have to set the relative value when you make the connection between nodes. Once I move through my time line, I will get value from unwanted frame.
I googled and stumbled upon ‘LagNode’, a very old maya plug in. From the description, this is exactly what I need. I planned to download the plugin and decipher to concept behind it, but the download is already expired.
https://www.3dbuzz.com/forum/threads/80514-lagNode-and-expressoUtils
Any advice here? Just a concept would be very appreciated.
Thanks,
Bird.
