Make combobox items checkable(multi-selection) in Mari
qt
python
I want to populate a combobox with udims of current geometry and I also want to make it checkable.
I have applied a model to combobox as a data. Here’s my code
from PySide.QtGui import *
from PySide.QtCore import *
cmb = QComboBox()
udims = [udim.name() for udim in mari.current.geo().patchList() ]
model = StandardItemModel(len(udims), 1)
for i, udim in enumerate(udims):
    item = QStandardItem(udim)
    item.setFlags(Qt.ItemIsUserCheckable | ItemIsEnabled)
    item.setData(Qt.Checked | Qt.CheckStateRole)
    model.setItem(item)
cmb.setModel(model)
Behavior of combox is changed but no checkbox is visible nor the items are selectable. I can’t figure out what’s the problem.
#2
I was able to get this working by creating a subclass of QItemDelegate for the checkbox, then plugging that into the item delegate for the combobox. I didn’t use geometry but instead some random uuids to illustrate the point. Tested in Mari 3.3v1.
# Built in
from uuid import uuid4
# Third party
from PySide.QtCore import Qt
from PySide.QtGui import (
     QComboBox,
     QMainWindow,
     QVBoxLayout,
     QPushButton,
     QItemDelegate,
     QStandardItem,
     QStandardItemModel
# Custom
ROWS = 10
class CheckBoxDelegate(QItemDelegate):
    """ Check box delegate """
        """ Initialization """
        super(CheckBoxDelegate, self).__init__(parent)
    def createEditor(parent, op, idx):
        """ Creates the checkbox """
        self.editor = QCheckBox(parent)
class MainWin(QDialog):
    """ Main window """
        super(MainWin, self).__init__(parent)
        self.setWindowTitle('Test Window')
        self.main_layout = QVBoxLayout()
        self.setLayout(self.main_layout)
        self.item_model = QStandardItemModel(ROWS, 1)
        self.combobox = QComboBox()
        self.checkboxdel = CheckBoxDelegate()
        self.combobox.setItemDelegate(self.checkboxdel)
        self.insert_test_data()
        self.combobox.setModel(self.item_model)
        self.main_layout.addWidget(self.combobox)
        self.test_button = QPushButton('Print checked items')
        self.test_button.clicked.connect(self.test_clicked)
        self.main_layout.addWidget(self.test_button)
    def insert_test_data(self):
        """ Inserts test uuids into a combobox widget. """
        for i in range(0, ROWS):
            item = QStandardItem(str(uuid4()))
            item.setCheckable(True)
            item.setSelectable(False)
            self.item_model.setItem(i, 0, item)
    def test_clicked(self):
        """ Prints info on checked items on click. """
            item = self.item_model.item(i, 0)
            print(item.text(), item.checkState())
if __name__ == '__main__':
    win = MainWin()
    win.show()
#4
Thank you very much. I was facing this issue for a whole week.
