Good morning variable creators:
We have just started testing Max 2015 and have been looking at the Python/Pyside implementation. We currently use the Blur Python methodology, alongside our own additions to the PyQt4 elements, but we are considering changing the studio to only use the MaxPlus classes etc. as we are (fingers and toes crossed) hoping that Autodesk will actually follow through and realise that the implementation of Python to Max in a proper way, is the way forward. Especially when you look at the benefits it has brought to Maya (an Autodesk product!), someone must have thought it can be used in Max. However, I digress.
The PySide Ui example that ships with the app is a good start, but there is no code that parents the ui to the main Max window, which we believe is a fundamental requirement as it is much better to have any relative ui stay with the Max window when minimizing/maximizing and stays on top of the window unless minimized by choice. Has anyone seen or found any code that supports the parenting of a pyside ui?:curses:
I have looked at the Chris Diggins article but its using a class (qtwinmigrate) that is for PyQt4. We are not looking to complie PyQt4 for use in this way, so a pyside solution is what we need.
Any feedback will be welcome.
