I am trying to implement a Drop Window using the MASH api
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-Tech-Docs/MASH/DropWindow.html
You can see in the example (copied below) that it works as a python generator, which I’m quite new to. I am really confused about the seemingly cyclical reference to “smartPreset” - it’s defined outside the function but referenced inside the function.
It all seems to work fine when run directly, but I want to import my script as a module and call the function to build the window. That’s where it all falls apart and I get a NameError. How can I create this generator window after I import it as a module? I hope that makes sense, I’m fumbling my way through this.
import flux.core as fx
def runPreset():
... Some cool code ...
fx.DropWindow.getDrop(label='Put a window title here:', callback=lambda data: smartPreset.send(data))
node = yield
'node' will be a string of all the nodes you dropped onto the Drop Window
Multiple nodes will be newline seperated.
One way to split the string is like so:
nodeList = node.split('\n')
print nodeList # print it out so that this example actually does something
Finish the Generator with a Yield so that it knows where to stop.
yield
Now run your Smart Preset like so
smartPreset = runPreset()
smartPreset.next()
