Been struggling past few days to allow drag and dropping from Maya’s Outliner to a custom QTreeWidget.
Current code:
class HierarchyWidget(QTreeWidget):
""" Subclass of QTreeWidget to support Drag and Drop in Maya. """
super(HierarchyWidget, self).__init__(parent=parent)
self.setDragDropMode(self.DragDrop)
self.setDefaultDropAction(Qt.MoveAction)
self.setDropIndicatorShown(True)
self.setDragEnabled(True)
# self.setAcceptDrops(True)
# self.setDragDropOverwriteMode(True)
rootItem = self.invisibleRootItem()
rootItem.setFlags(Qt.ItemIsDropEnabled)
viewport = self.viewport()
viewport.setAcceptDrops(True)
print(self.mimeTypes())
def mimeTypes(self):
return 'application/x-maya-data'
def dropEvent(self, event):
print("Dropped!")
def supportedDropActions(self):
return Qt.MoveAction | Qt.CopyAction
I add this widget into a QWidget with QGridLayout (if that matters)
So far think I’ve iterated through all possible Drag and Drop Modes, tried setting an invisible root item for the Tree - rewrote the code on: https://kylemr.blogspot.se/2013/04/pyqt-drag-and-drop-outliner-like.html to fit PySide but seems that code couldn’t handle drag and drop either.
Using Maya 2018, PySide.version = 2.0.0~alpha0
