Photoshop CC and HTML5
Has anyone been able to successfully launch an HTML5 UI within Photoshop CC 2014 (v15.2)
I have been using this as a guide:
http://www.adobe.com/devnet/creativesuite/articles/a-short-guide-to-HTML5-extensions.html
and I’m hung up on this step:
On Windows, copy the extension into %APPDATA%\Adobe\CEPServiceManager4\extensions
Things I’ve tried:
That folder doesn’t exist on my workstation, creating it and placing my HTML/manifest there doesn’t help. Creating one called CEPServiceManager5 also doesn’t work. Tried about 3-4 other logical locations…no luck.
Tried installing another extension to see where it places files, but since our workstations have no internet connection (and extension manager cc calls home), I cannot do that. Trying to use their request workaround com es to another dead end.
#2
Trying this:
http://aphall.com/2014/08/cep-mega-guide-en/
This worked!
Here’s the important bit, place the HTML5 markup here:
Win 32bit:C:\Program Files\Common Files\Adobe\CEP\extensions
Win 64bit:C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\
#3
Is it just me or is it super weird that Photoshop 64bit looks in the x86 folder??
Edit: Has anybody had luck launching external exe files through javascript? I get an Uncaught ReferenceError: ActiveXObject is not defined. I’m guessing I’m not allowed to because of security reasons, but surely there must be a way?
#4
We do it all the time, from photoshop you use
app.system(cmd)
, in aftereffects it’s
system.callSystem(cmd)
. I’ve never seen that error, are those the commands you’re using?
With CEP, you can also either use the CEP call or node.js.
window.cep.process.createProcess(process_path, process_args);
with node,
try {
    node_exec = require("child_process").exec;
} catch(err) {
    console.log("didn't get exec");
    console.log(err);
launch_app = function(){
            node_exec(['"X:\\appdir\app.exe"'],
                {cwd: "X:\\appdir"},
                function (err, out, code) {
                    if (err instanceof Error)
                        throw err;
                    console.log(err);
                    console.log(out);
                    console.log(code);
[QUOTE=Optagon;26528]Is it just me or is it super weird that Photoshop 64bit looks in the x86 folder??
Edit: Has anybody had luck launching external exe files through javascript? I get an Uncaught ReferenceError: ActiveXObject is not defined. I’m guessing I’m not allowed to because of security reasons, but surely there must be a way?[/QUOTE]
