Whats simplest way of distributing and auto-updating Photoshop extensions in Photoshop CC 2014?
I created extension, if I run photoshop with devel registry value it works, but when I directly copy com.XXX.XXX folder to other users AppData it doesn’t load as its unsigned.
Is it easier to distribute .zxp? I had problem that Extension Manager plugin needs older photoshop, even if I tweeked manifest file.
How do you work with that?
