The order actually follows sys.path
, you can actually find the userSetup.py
behavior in maya.app.startup.basic.executeUserSetup
, in fact if you need to rerun userSetup
for some reason you can call that function and it will do so.
You are correct that this all runs well before the GUI.
However, I would do this a bit differently, instead of passing a string into executeDeferred
you can hand it the function object and it will call it for you at the proper time. The nice thing about this is you can pass *args, **kwargs
along with it.
import maya
def yourMethodName(standalone=False):
#do python stuff here once GUIās loaded.
pass
maya.utils.executeDeferred(yourMethodName, standalone=True)
