Converting tiff file to tx file through maketx utility
python
texturing
This is tne format of maketx.exe command
maketx -v -u --oiio --checknan --filter lanczos3 inputFile.tiff -o fileOut.tx
I can successfully convert my tiff files to tx files by running it on cmd.exe
But when I call this command through subprocess.Popen() like this
subprocess.Popen(["maketx.exe", "-v -u --oiio --checknan --filter lanczos3", "inputFile.tiff", "-o", "fileOut.tx"])
It gives me this error
Invalid option " -v -u --oiio --checknan --filter lanczos3"
am I missing something or I’m using subprocess wrong way?
#2
In the Python subprocess Popen documentation it states:
If args is a string, the interpretation is platform-dependent and described below. See the shell and executable arguments for additional differences from the default behavior. Unless otherwise stated, it is recommended to pass args as a sequence.
Considering you are using an exe I assume you are on Windows, which further states:
A string surrounded by double quotation marks is interpreted as a single argument, regardless of white space contained within. A quoted string can be embedded in an argument.
So to me it looks like that invalid statement is being interpreted as a single argument, but those are multiple args, so you should convert it to a sequence like the others.
https://docs.python.org/2/library/subprocess.html
https://docs.python.org/2/library/subprocess.html#converting-argument-sequence
#3
Yeah, my guess is that @sev nailed it. Try something like this:
subprocess.Popen(["maketx.exe", "-v",  "-u",  "--oiio", "--checknan", "--filter", "lanczos3", "inputFile.tiff", "-o", "fileOut.tx"])
#4
Yes! It worked! Thanks
