Executing a function after set interval
I want to force save my project file every x minutes, is there a maya function to add timed events?
The workaround that I’ve found is to create an extra thread and put a while loop into it and then use executeDeferred
class Test(threading.Thread):
    def __init__(self):
        threading.Thread__init__(self)
    def run(self):
        while True:
            maya.utils.executeDeferred(maya.cmds.file, s=True)
            time.sleep(300)
Thanks
Generally what you’re doing is the usual way – you probably want to use executeInMainThreadWithResult (is that the one you meant) or executeDeferred – otherwise pretty much anything in maya.cmds will crash in odd ways if triggered from another thread.
You can also use an idle-time scriptjob to check your timer, that won’t run if Maya is busy (probably a benefit for this application).
This github project emulates threads but uses idle events under the hood to implement timers and so on in a thread-safe way.
Thanks and yes there was a typo, I am using executeDeferred
