Hi all,
I have this model in which some of the geometries within are not uv-ed.
As in, you select the geometry >> open up uv editor >> it is blank.
And so it is causing some problems with a script I am doing. Are there any ways in which I can use python to check for such geos with the blank uvs?
FYI, there is only 1 uv set for this model.
