Get VertexData Alpha from a Mesh
csharp
Hello,
I’m trying to get vertices alpha values from a Mesh using 3dsMax SDK (DotNet version).
int VDATA_ALPHA = 2;
// assuming triObj is a valid ITriObject
// check if Vertex Alpha Data is supported
if (!triObj.Mesh.VDataSupport(VDATA_ALPHA))
    MaxUtils.MxsLogger("ENABLING SUPPORT ALPHA");
    triObj.Mesh.SetVDataSupport(VDATA_ALPHA, true);
        MaxUtils.MxsLogger("UNABLE TO SUPPORT ALPHA");
// get an array of float with vertex alpha data values
IntPtr alphaRawValues = triObj.Mesh.VertexFloat(VDATA_ALPHA);
if (alphaRawValues != null && alphaRawValues != IntPtr.Zero)
    MaxUtils.MxsLogger(alphaRawValues.ToString());                     // print the pointer address
    float[] alphaBytes = new float[triObj.Mesh.NumVerts];
    Marshal.Copy(alphaRawValues, alphaBytes, 0, triObj.Mesh.NumVerts); // fill the float array using values stored at this address
    MaxUtils.MxsLogger("ALPHA VALUES : ");
    foreach (float b in alphaBytes)
        MaxUtils.MxsLogger(b.ToString());
I tried this code in 2 differents scenarios, the first one on a Editable_Spline with an Edit Mesh modifier on top of its stack, and the second one on an Editable_Mesh.
Scenario 1 results:
  • Since the mesh is always re-evaluated (the object by reference on the node is a Shape), the alpha data support is always false, and the code needs to re-enable it.
  • The pointer address is always changing, which is understandable too.
  • All values (4 values for a rectangle by example) are equals to 1, no matter if i change Alpha values in the Modify panel.
Scenario 2 results:
  • The support needs to be enabled once.
  • The pointer address doesn’t change.
  • All values are, again, equals to 1.
So what is the way to get this vertex alpha values ?
EDIT
It seems i was looking for at the wrong place. Indeed the Alpha parameter value from Surface Properties panel is not stored in vertex data, but in map channel -2.
What i tried so far :
if (!triObj.Mesh.MapSupport(-2))
    MaxUtils.MxsLogger("ENABLING MAP SUPPORT ALPHA");
    triObj.Mesh.SetMapSupport(-2, true);
        MaxUtils.MxsLogger("UNABLE TO MAP SUPPORT ALPHA");
IMeshMap alphaMap = triObj.Mesh.Map(-2);
if (alphaMap == null)
    MaxUtils.MxsLogger("UNABLE TO GET ALPHA MAP");
else if (alphaMap.NumVerts > 0)
    IPoint3 alphaValues = alphaMap.Tv;
The weird thing happens here, the Tv properties of my IMeshMap is a IPoint3 instance, instead of an array of values like in the C++ SDK… i even feel like it’s a mistake from Autodesk, regarding the comment above the property :
// Autodesk.Max.IArray of texture vertices. This stores the UVW coordinates for
// the mapping channel. Note: typedef Autodesk.Max.IPoint3 UVVert;
How can I retrieve my values from this property ?
Thank you.
#2
I have finally found a workaround. I always think there’s a mistake in the DotNet wrapper about what kind of data returns the Tv property.
My workaround was to handle my mesh as a IMNMesh instead of IMesh (more functionalities but slower operations).
IMNMesh mnmesh = MaxInterfaces.Global.MNMesh.Create(triObj.Mesh);
IMNMap alphaMap = mnmesh.M(-2);
if (alphaMap.Numv > 0)
    for (int i = 0; i < alphaMap.Numv; i++)
        MaxUtils.MxsLogger(string.Format("Alpha value for vertex {0} : {1}", i.ToString(), alphaMap.V(i).X.ToString()));
