For those curious. This was the code in questioning.
I wrote my first custom maya api command, which will transfer vertexColors from one channel to the other, or from one colorSet to the other. Multiple channels/sets can be set.
This isn’t heavily tested yet, so if you want to use it use with caution
If anyone sees something that I could improve let me know! I’m always happy for some feedback
import sys
import maya.OpenMaya as om
import maya.OpenMayaMPx as omMPx
commandName = "transferColors"
kObjectNameFlag = "-n"
kObjectNameLongFlag = "-name"
kObjectRedFlag = "-r"
kObjectRedLongFlag = "-colorR"
kObjectGreenFlag = "-g"
kObjectGreenLongFlag = "-colorG"
kObjectBlueFlag = "-b"
kObjectBlueLongFlag = "-colorB"
kObjectAlphaFlag = "-a"
kObjectAlphaLongFlag = "-alpha"
kObjectColorSet1Flag = "-s1"
kObjectColorSet1LongFlag = "-set1"
kObjectColorSet2Flag = "-s2"
kObjectColorSet2LongFlag = "-set2"
kHelpFlag = "-h"
kHelpLongFlag = "-help"
helpMessage = """This command is used to transfer vertex colors per channel and from one colorSet to the other.\n"""
class pluginCommand(omMPx.MPxCommand):
If no colorSet is specified the current one will be used.
-r, -g, -b, -a = [index colorSet (0/1), index vertexColor (0/1/2/3)]
set1 = colorSet
set2 = colorSet"""
def __init__(self):
self.meshFn = None
self.sourceColors = None
self.polygons = []
self.vertices = []
self.r = None
self.g = None
self.b = None
self.a = None
self.set1 = None
self.set2 = None
omMPx.MPxCommand.__init__(self)
def argumentParser(self, argList):
syntax = self.syntax()
parsedArguments = om.MArgDatabase(syntax, argList)
# Get selection
selection = om.MSelectionList()
parsedArguments.getObjects(selection)
component = om.MObject()
mDagPath = om.MDagPath()
selection.getDagPath(0, mDagPath, component)
self.meshFn = om.MFnMesh(mDagPath)
# Parse all flags
if parsedArguments.isFlagSet(kHelpFlag):
self.setResult(helpMessage)
if parsedArguments.isFlagSet(kObjectRedFlag):
idx1 = parsedArguments.flagArgumentInt(kObjectRedFlag, 0)
idx2 = parsedArguments.flagArgumentInt(kObjectRedFlag, 1)
if idx1 > 1 or idx2 > 3:
return False
self.r = [idx1, idx2]
if parsedArguments.isFlagSet(kObjectGreenFlag):
idx1 = parsedArguments.flagArgumentInt(kObjectGreenFlag, 0)
idx2 = parsedArguments.flagArgumentInt(kObjectGreenFlag, 1)
return False
self.g = [idx1, idx2]
if parsedArguments.isFlagSet(kObjectBlueFlag):
idx1 = parsedArguments.flagArgumentInt(kObjectBlueFlag, 0)
idx2 = parsedArguments.flagArgumentInt(kObjectBlueFlag, 1)
return False
self.b = [idx1, idx2]
if parsedArguments.isFlagSet(kObjectAlphaFlag):
idx1 = parsedArguments.flagArgumentInt(kObjectAlphaFlag, 0)
idx2 = parsedArguments.flagArgumentInt(kObjectAlphaFlag, 1)
return False
self.a = [idx1, idx2]
if parsedArguments.isFlagSet(kObjectColorSet1Flag):
self.set1 = parsedArguments.flagArgumentString(kObjectColorSet1Flag, 0)
if parsedArguments.isFlagSet(kObjectColorSet2Flag):
self.set2 = parsedArguments.flagArgumentString(kObjectColorSet2Flag, 0)
# If no colorSet is defined use current
if not self.set1:
self.set1 = self.meshFn.currentColorSetName()
if not self.set2:
self.set2 = self.meshFn.currentColorSetName()
if not self.set1 and not self.set2:
sys.stderr.write("Object has no colorSets.\n")
return False
# Get components
if not component.isNull():
if component.hasFn(om.MFn.kMeshPolygonComponent):
self.polygons = om.MIntArray()
om.MItMeshPolygon(mDagPath, component)
face_itr = om.MItMeshPolygon(mDagPath, component)
while not face_itr.isDone():
self.polygons.append(face_itr.index())
face_itr.next()
elif component.hasFn(om.MFn.kMeshEdgeComponent):
om.MItMeshEdge(mDagPath, component)
edge_itr = om.MItMeshEdge(mDagPath, component)
while not edge_itr.isDone():
self.vertices.append(edge_itr.index(0))
self.vertices.append(edge_itr.index(1))
edge_itr.next()
elif component.hasFn(om.MFn.kMeshVertComponent):
self.vertices = om.MIntArray()
om.MItMeshVertex(mDagPath, component)
vert_itr = om.MItMeshVertex(mDagPath, component)
while not vert_itr.isDone():
self.vertices.append(vert_itr.index())
vert_itr.next()
return True
def isUndoable(self):
return True
def doIt(self, argList):
if self.argumentParser(argList) and (self.r or self.g or self.b or self.a):
# get current colors and store it for undo
self.sourceColors = om.MColorArray()
self.meshFn.getFaceVertexColors(self.sourceColors, self.set1)
self.redoIt()
else:
sys.stderr.write("No flag specified or setup incorrectly for '%s' command.\n" % commandName)
def redoIt(self):
meshFn = self.meshFn
vertexCount = om.MIntArray()
vertexList = om.MIntArray()
meshFn.getVertices(vertexCount, vertexList)
# Set2 colors
sourceColors2 = om.MColorArray()
meshFn.getFaceVertexColors(sourceColors2, self.set2, om.MColor(0, 0, 0, 1))
# Set1 colors
targetColors = om.MColorArray()
meshFn.getFaceVertexColors(targetColors, self.set1, om.MColor(0, 0, 0, 1))
# inner function to transfer colors from set2 to set1
def transferColors(i):
if self.r:
if self.r[0] == 0:
targetColors[i].r = self.sourceColors[i][self.r[1]]
elif self.r[0] == 1:
targetColors[i].r = sourceColors2[i][self.r[1]]
if self.g:
if self.g[0] == 0:
targetColors[i].g = self.sourceColors[i][self.g[1]]
elif self.g[0] == 1:
targetColors[i].g = sourceColors2[i][self.g[1]]
if self.b:
if self.b[0] == 0:
targetColors[i].b = self.sourceColors[i][self.b[1]]
elif self.b[0] == 1:
targetColors[i].b = sourceColors2[i][self.b[1]]
if self.a:
if self.a[0] == 0:
targetColors[i].a = self.sourceColors[i][self.a[1]]
elif self.a[0] == 1:
targetColors[i].a = sourceColors2[i][self.a[1]]
i = 0 # faceVertex index
colorIds = om.MIntArray()
for polygon in range(vertexCount.length()):
for faceVert in range(vertexCount[polygon]):
# Check if any components are selected
if self.polygons or self.vertices:
# Only transfer selected components
if polygon in self.polygons or vertexList[i] in self.vertices:
transferColors(i)
else:
transferColors(i)
# Add faceVertex to colorIds
colorIds.append(i)
i += 1
# Apply colors to all faceVertices
meshFn.setColors(targetColors, self.set1)
meshFn.assignColors(colorIds, self.set1)
meshFn.setCurrentColorSetName(self.set1)
def undoIt(self):
for i in range(vertexList.length()):
colorIds.append(i)
# Apply old colors (pre doIt)
meshFn.setColors(self.sourceColors, self.set1)
def syntaxCreator():
syntax = om.MSyntax()
# Add objects/selection to the syntax
syntax.useSelectionAsDefault(True)
syntax.setObjectType(om.MSyntax.kSelectionList)
# Add all needed flags
syntax.addFlag(kHelpFlag, kHelpLongFlag)
syntax.addFlag(kObjectRedFlag, kObjectRedLongFlag, om.MSyntax.kUnsigned, om.MSyntax.kUnsigned) # 2x om.MSynstax.kUnsigned to create a float2 parameter
syntax.addFlag(kObjectGreenFlag, kObjectGreenLongFlag, om.MSyntax.kUnsigned, om.MSyntax.kUnsigned)
syntax.addFlag(kObjectBlueFlag, kObjectBlueLongFlag, om.MSyntax.kUnsigned, om.MSyntax.kUnsigned)
syntax.addFlag(kObjectAlphaFlag, kObjectAlphaLongFlag, om.MSyntax.kUnsigned, om.MSyntax.kUnsigned)
syntax.addFlag(kObjectColorSet1Flag, kObjectColorSet1LongFlag, om.MSyntax.kString)
syntax.addFlag(kObjectColorSet2Flag, kObjectColorSet2LongFlag, om.MSyntax.kString)
return syntax
def cmdCreator():
return omMPx.asMPxPtr(pluginCommand())
def initializePlugin(mobject):
mplugin = omMPx.MFnPlugin(mobject, "Jeroen Heemskerk", "1.0")
try:
mplugin.registerCommand(commandName, cmdCreator, syntaxCreator)
except:
sys.stderr.write("Failed to register command: %s.\n" % commandName)
def uninitializePlugin(mobject):
mplugin = omMPx.MFnPlugin(mobject)
try:
mplugin.deregisterCommand(commandName)
except:
sys.stderr.write("Failed to de-register command: %s.\n" % commandName)
