[Maya] Edit Normals Tool on harden edges
Hi, I was wondering if there is a way to edit vertex normals (with the edit Normals tool) from 2 faces with harden, so instead of editing both vertex normals at the same time, edit one at a time.
I would like to control each vertex normal because the tool is merging both vertex normals.
Any ideas?
Thanks in advance!
#2
I’ve not tried this, so it is just a guess, but you might be able to do this by selecting the vertex-face component and editing the normal through that.
#3
Yep! it works!! :slight_smile: Didn’t´t know that.
Thank you so much!!
