Hello Guys,
I not strong at mel, i have some questions about this command.
I need change .pointLock atribute for all selected hair curves, how its do correctly?
My variant script not works with nHair node
//Lists the transform nodes of all selected objects
string $nodes[] = ls -selection;
for ($node in $nodes)
//Loop through each object and obtain its shape node
string $shapes[] = listRelatives -shapes $node;
//Set the visibility attribute of each shape node to 0
//The shape node is saved to the 1st (or 0th) element of the $shape array
setAttr ($shapes[0] + ".pointLock") (0);
Thanks for help
