Hey guys,
i’m just starting to learn maya’s python scripting and i’m having problems with vertex color information updating in a deformer.
at the end of the deform function i’m calling:
mesh.setVertexColors(vertex_color_list, vertex_index_list)
and everything works fine except the result doesnt show up untill i use some tool on the mesh. Any ideas why is that happening?
Here’s the code:
import sys
import maya.OpenMaya as OpenMaya
import maya.OpenMayaMPx as OpenMayaMPx
# Helper functions
def clamp(min_value,max_value,value):
return max(min(value, max_value), min_value)
def saturate(value):
return clamp(0, 1, value)
def mapValue(min_value, max_value, value):
return saturate((value - min_value)/(max_value - min_value))
def cutout(min_value, value):
if value < min_value:
return 0
else:
return value
# Plugin information
plugin_node_name = 'SM_Damage'
plugin_node_id = OpenMaya.MTypeId(0x1C3B0476)
maya_api_version = OpenMaya.MGlobal.apiVersion()
# get the input and geometry based on the maya version
if maya_api_version < 201600:
input_attr = OpenMayaMPx.cvar.MPxDeformerNode_input
input_geom_attr = OpenMayaMPx.cvar.MPxDeformerNode_inputGeom
output_geom_attr = OpenMayaMPx.cvar.MPxDeformerNode_outputGeom
else:
input_attr = OpenMayaMPx.cvar.MPxGeometryFilter_input
input_geom_attr = OpenMayaMPx.cvar.MPxGeometryFilter_inputGeom
output_geom_attr = OpenMayaMPx.cvar.MPxGeometryFilter_outputGeom
# get the envelope based on the maya version
envelope_attr = OpenMayaMPx.cvar.MPxDeformerNode_envelope
else:
envelope_attr = OpenMayaMPx.cvar.MPxGeometryFilter_envelope
class SM_DamageDeformerNode(OpenMayaMPx.MPxDeformerNode):
rust_exponent_attr = OpenMaya.MObject()
rust_black_point_attr = OpenMaya.MObject()
rust_multiplier_attr = OpenMaya.MObject()
# metal_attributes
metal_exponent_attr = OpenMaya.MObject()
metal_black_point_attr = OpenMaya.MObject()
metal_multiplier_attr = OpenMaya.MObject()
# AO_attributes
AO_exponent_attr = OpenMaya.MObject()
AO_black_point_attr = OpenMaya.MObject()
AO_multiplier_attr = OpenMaya.MObject()
def __init__(self):
''' Constructor. '''
# (!) Make sure you call the base class's constructor.
OpenMayaMPx.MPxDeformerNode.__init__(self)
def clamp(min_value, max_value, value):
def get_input_geom(self, data, geom_idx):
input_handle = data.outputArrayValue(input_attr)
input_handle.jumpToElement(geom_idx)
input_geom_obj = input_handle.outputValue().child(input_geom_attr).asMesh()
return input_geom_obj
#END
def deform(self, data, geom_it, local_to_world_mat, geom_idx):
rust_exponent_handle = data.inputValue(SM_DamageDeformerNode.rust_exponent_attr)
rust_black_point_handle = data.inputValue(SM_DamageDeformerNode.rust_black_point_attr)
rust_multiplier_handle = data.inputValue(SM_DamageDeformerNode.rust_multiplier_attr)
# metal_handles
metal_exponent_handle = data.inputValue(SM_DamageDeformerNode.metal_exponent_attr)
metal_black_point_handle = data.inputValue(SM_DamageDeformerNode.metal_black_point_attr)
metal_multiplier_handle = data.inputValue(SM_DamageDeformerNode.metal_multiplier_attr)
# AO_handles
AO_exponent_handle = data.inputValue(SM_DamageDeformerNode.AO_exponent_attr)
AO_black_point_handle = data.inputValue(SM_DamageDeformerNode.AO_black_point_attr)
AO_multiplier_handle = data.inputValue(SM_DamageDeformerNode.AO_multiplier_attr)
# set final variables
rust_exponent = rust_exponent_handle.asFloat()
rust_black_point = rust_black_point_handle.asFloat()
rust_multiplier = rust_multiplier_handle.asFloat()
# metal_attributes
metal_exponent = metal_exponent_handle.asFloat()
metal_black_point = metal_black_point_handle.asFloat()
metal_multiplier = metal_multiplier_handle.asFloat()
# AO_attributes
AO_exponent = AO_exponent_handle.asFloat()
AO_black_point = AO_black_point_handle.asFloat()
AO_multiplier = AO_multiplier_handle.asFloat()
# creates OpenMaya mesh object
input_geom_obj = self.get_input_geom(data, geom_idx)
mesh = OpenMaya.MFnMesh(input_geom_obj)
mesh_iterator = OpenMaya.MItMeshVertex(input_geom_obj)
vertex_count = mesh_iterator.count()
# Retrieve mesh data
fnComponent = OpenMaya.MFnSingleIndexedComponent()
fullComponent = fnComponent.create(OpenMaya.MFn.kMeshVertComponent)
fnComponent.setCompleteData(vertex_count)
vertex_index_list = OpenMaya.MIntArray()
# get vertex index list
fnComponent.getElements(vertex_index_list)
# get vertex normals
normals = OpenMaya.MFloatVectorArray()
space = OpenMaya.MSpace.kObject
mesh.getVertexNormals(True, normals, space)
vertex_color_list = OpenMaya.MColorArray()
for i in range(vertex_count):
vertex_color_list.setLength(vertex_count)
vertex_color_list.set(i, 0, 0, 0)
# iterate over all vertices
while not mesh_iterator.isDone():
# collect current vertex data
index = mesh_iterator.index()
# get current vertex normal
normal = OpenMaya.MVector(normals[index])
vertex_color = OpenMaya.MColor()
# get current vertex position
position_a = mesh_iterator.position(space)
# retrieve connected indices
connected_vertices = OpenMaya.MIntArray()
mesh_iterator.getConnectedVertices(connected_vertices)
dot_product_min = 1.0
dot_product_max = -1.0
# calculate concavity/convexity data
# print "vertex ", index
# print "position x", "%.3f" % position_a.x, ", y", "%.3f" % position_a.y, ", z", "%.3f" % position_a.z
# print "N: x", "%.3f" % normal.x, ", y", "%.3f" % normal.y, ", z","%.3f" % normal.z
for k in connected_vertices:
position_b = OpenMaya.MPoint()
mesh.getPoint(k, position_b, space)
# create edge vector
edge_vector = position_b - position_a
edge_vector.normalize()
# calculate dot product
dot_product = edge_vector * normal
if dot_product < dot_product_min:
dot_product_min = dot_product
if dot_product > dot_product_max:
dot_product_max = dot_product
# END IF
# END FOR
# print "factor: ", "%.3f" % dot_product_min
def calculate_value(change_sign, exponent, black_point, final_multiplier):
# print color_value
if change_sign:
color_value = dot_product_min
color_value *= -1
else:
color_value = saturate(color_value)
color_value = pow(color_value, exponent)
color_value = cutout(black_point, color_value)
color_value = color_value * final_multiplier
return color_value
# print rust_value
vertex_color.r = calculate_value(False, AO_exponent, AO_black_point, AO_multiplier)
vertex_color.g = calculate_value(True, rust_exponent, rust_black_point, rust_multiplier)
vertex_color.b = calculate_value(True, metal_exponent, metal_black_point, metal_multiplier)
vertex_color_list.set(vertex_color, index)
mesh_iterator.next()
#END deform
def nodeCreator():
return OpenMayaMPx.asMPxPtr(SM_DamageDeformerNode())
#END
def nodeInitializer():
num_attr = OpenMaya.MFnNumericAttribute()
# setup attributes
# rust black point
SM_DamageDeformerNode.rust_black_point_attr = num_attr.create('rust_black_point', 'rbp',
OpenMaya.MFnNumericData.kFloat, 0.0)
num_attr.setMin(0.0)
num_attr.setMax(1.0)
num_attr.setChannelBox(True)
num_attr.setStorable(True)
num_attr.setWritable(True)
num_attr.setReadable(False)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.rust_black_point_attr)
# metal black point
SM_DamageDeformerNode.metal_black_point_attr = num_attr.create('metal_black_point', 'mbp',
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.metal_black_point_attr)
# AO black point
SM_DamageDeformerNode.AO_black_point_attr = num_attr.create('AO_black_point', 'aobp',
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.AO_black_point_attr)
# rust exponent
SM_DamageDeformerNode.rust_exponent_attr = num_attr.create('rust_exponent', 'rexp',
OpenMaya.MFnNumericData.kFloat, 1.0)
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.rust_exponent_attr)
# metal exponent
SM_DamageDeformerNode.metal_exponent_attr = num_attr.create('metal_exponent', 'mexp',
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.metal_exponent_attr)
# AO exponent
SM_DamageDeformerNode.AO_exponent_attr = num_attr.create('AO_exponent', 'aoexp',
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.AO_exponent_attr)
# rust multiplier
SM_DamageDeformerNode.rust_multiplier_attr = num_attr.create('rust_multiplier', 'rmul',
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.rust_multiplier_attr)
# metal_multiplier
SM_DamageDeformerNode.metal_multiplier_attr = num_attr.create('metal_multiplier', 'mmul',
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.metal_multiplier_attr)
# AO_multiplier
SM_DamageDeformerNode.AO_multiplier_attr = num_attr.create('AO_multiplier', 'aomul',
num_attr.setMax(10)
SM_DamageDeformerNode.addAttribute(SM_DamageDeformerNode.AO_multiplier_attr)
print dir(OpenMayaMPx.cvar)
# set Attribute affects
# black points
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.metal_black_point_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.AO_black_point_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.rust_black_point_attr,output_geom_attr)
# exponents
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.metal_exponent_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.AO_exponent_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.rust_exponent_attr,output_geom_attr)
# multipliers
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.metal_multiplier_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.AO_multiplier_attr,output_geom_attr)
SM_DamageDeformerNode.attributeAffects(SM_DamageDeformerNode.rust_multiplier_attr,output_geom_attr)
#END
def initializePlugin(mobject):
mplugin = OpenMayaMPx.MFnPlugin(mobject)
try:
mplugin.registerNode(plugin_node_name, plugin_node_id, nodeCreator, nodeInitializer, OpenMayaMPx.MPxNode.kDeformerNode)
except:
sys.stderr.write('Failed to register node: ' + plugin_node_name)
raise
#END
def uninitializePlugin(mobject):
''' Uninitializes the plug-in '''
try:
mplugin.deregisterNode(plugin_node_id)
except:
sys.stderr.write('Failed to deregister node: ' + plugin_node_name)
raise
