Anyone have any tips on this?
You’ve got a stretchy spline IK setup, but the end joint doesn’t ALWAYS have the same location as the last cv in the splineIK curve (when it can’t solve it, I guess). This is part of a control skeleton.
Should I:
*) try to constrain / utility node the end joint so it’s always on the last cv.
*) ignore the last joint, and just put in a “fix” joint that’s constrained to the last cv location, then use that fix joint for controlling the bind skeleton (instead of the original last joint in the spline IK)
*) something else.
*) something wonderful.
Any input is appreciated.
