Photoshop: Event listener for layer selections
I read Davide’s intro to Photoshop event listeners using the CSEvent class:
And long story short: I got things working but I can’t seem to make an event trigger on a layer selection.
Using the charID “slct” makes the event fire when using any of the selection tools (polygon lasso, magic wand, etc) but not when selecting layers.
I found some related threads on the Adobe boards:
https://forums.adobe.com/thread/1056469
https://forums.adobe.com/thread/1247256
…but in neither case are they working with CSEvent.
If I understand this correctly, I need to provide additional parameters to my event.data before dispatching the event with csInterface.dispatchEvent(event) - but how? I don’t understand the syntax fully, and the documentation isn’t all that good.
JS
(function(){
    'use strict';
    var csInterface = new CSInterface();
    var event = new CSEvent("com.adobe.PhotoshopRegisterEvent", "APPLICATION");
    event.extensionId = "com.example.psevents";
    event.data = "1936483188"; // charIDToTypeID("slct") - which is "select"
    csInterface.dispatchEvent(event);
    function init(){
        // code
    function PSCallback(csEvent){
        alert("it works!");
    init();
    csInterface.addEventListener("PhotoshopCallback", PSCallback);
The callback here is fired off on selections, but not the ones of the type I want! It works on selections done with the marquee tool, polygon lasso, etc - and when selecting color swatches in the swatches panel. But it doesn’t fire off on layer selections (which is the one and only event I want really).
Has anyone worked with this before and is able to provide some insights? Thanks.
