Store Path between Session
maxscript
Hi guys, sorry for my noob question.
I’m really new in maxscript . I need to store a string between different session on max.
How can I do?
Thanks
#2
This isn’t the most elegant approach admittedly, but we’ve typically simply stored file/directory path strings (and strings that are not path strings for that matter) in plain text files. If the strings are only really relevant to a particular file, you can either store the string data in the user properties of a node in the scene or in the max scene file’s file properties. And you could also checkout Asset Metadata. I’ve never personally messed with the latter, but it seems like a pretty useful feature on first blush (especially if you’ll need to access the string data using an application other than 3DS Max).
#3
yes this was my first idea.
As is just a temporary path my idea was to create a file in temp windows folder of the user.
But I thought , maybe there is a more elegant way.
I read about customAttributes . Shoud I use those or maybe I’m totally wrong?
#4
Sorry, my first reply came in a bit hot. :relaxed: I have since flesh out the post a bit with some additional options.
#5
At the end I wrote my strings into a file.txt
Thanks for you advice
