I have been trying to script a EXR screenshot tool for UE, using the take_high_res_screenshot function. But keep getting an error that says
LogPython: Error: AttributeError: type object ‘EditorLevelLibrary’ has no attribute 'get_all_viewports
Seems like the automation library missing, how do I fix this? can’t find any resources
does not belong to unreal.EditorLibrary
(but to unreal.AutomationLibrary
). Since the error is complaining about the EditorLibrary
object I’m guessing you’re using get_all_viewports
somewhere in your code and that object does not have that attribute.
You can try checking the Unreal Python docs for the Unreal version you’re using, maybe that get_all_viewports
attribute has been deprecated or changed names.
These are the Unreal Python API docs for 5.4: https://dev.epicgames.com/documentation/en-us/unreal-engine/python-api/?application_version=5.4
Either way, I’ve just tried the following code inside Unreal and I could successfully take a screenshot with EXR format:
import unreal
unreal.AutomationLibrary.take_high_res_screenshot(1024, 1024, filename='your_path/image_name.exr')
Hope it helps!
Thanks bunch, it works. I am really new to Python in UE. Do you have any clue how to integrate this script into the main UI? I am writing a UI for Unreal’s main interface. Do you have any thoughts?
Also I have been trying to calculate the viewport resolution rather than manually parsing the values, apparently get_all_viewports
doesn’t exist in unreal.EditorLibrary
are there any alternatives available? How do you calculating the current viewport resolution?
and tried take_automation_screenshot
still says no attributes in automation library, any clue how do fix all of these
Glad it helped
AFAIK you can either use UMG (Blueprint based) or slate (C++) to create custom UI in Unreal. You’ll find a lot of blueprint nodes operations if you use UMG, and if there’s something that’s only available in python you can always execute python code/scripts via blueprints nodes (e.g., https://www.youtube.com/watch?v=JP_EOAGS634). There’s plenty of tutorials online that teach how to implement UI in the engine.
I have no idea on how to get the viewport resolution, maybe there’s a blueprint node for it.
And regarding take_automation_screenshot
error it’s hard to tell without seeing the code but I’d recommend checking the Python Unreal API docs as it looks there’s an attribute that does not exist.
