Go to Parent option in bitmaptexture (missing breadcrumbs)
I have an extended version of a material in a material plugin. In it I have a button that I want to open a bitmaptexture’s properties page, which I’ve been able to do through medit. But when I open the bitmaptexture through medit it loses the breadcrumbs of its parent and I can no long click the Go to Parent button in the compact material editor. Below is a psudo-version that is simplified and tries to open the diffuse map from the standard material to show the issue.
Is there any way for me to bring up that bitmap texture properties page on this button press, while maintaining the option for Go To Parent?
plugin material TestMaterial
	classID:#(0x00000000, 0x00000000)
	extends:Standard version:1
	parameters MainOptions rollout:TestOptions
		filepath type:#string default:"\\Filepath"
	rollout TestOptions "Options"
		Group "Group1:"
            button openBitmap width:75 height:50
            on openBitmap pressed do
                difMap = delegate.diffuseMap
                medit.putMtlToMtlEditor difMap 1
Thank you!
