[maxscript] recall material under sub-material
Hello,
how can recall in maxscript a material inside of sub-material? i can’t get it.
Thanks a lot.
Your question is unclear. Could you please rephrase and provide a clearer explanation of the problem?
If your object is using a MultiMaterial (maxscript doc), the property <object>.material.materialList is a list of the materials inside the multi material.
You can get the material a face in your object is using by the getFaceMatID function, and you can match it up via <object>.material.materialIDList
rollout RolloutTemplate "Rename Material from Mesh"
		local sceneMats = #()
		button subDivsButton "Rename Mat from Mesh" width:170 height:30 pos:[0,20]
		on subDivsButton pressed do
							for object in objects do
										for i in selection do
											object.material.materialList[i] = sceneMats[i]
											print(sceneMats.count)
i have this code to make a “simple” script where:
renaming material (inside sub-material) like name of mesh.
each mesh have only one material
how can fix it?
