Hello,
been searching for a way to deselect the “enable transformation” property.
Can’t seem to find it anywhere, i searched under the FBModel class, there is the Show option and you can modify it, but no Enable Transformation or Enable Selection.
Did they have a different name before? The other properties don’t seem to apply.
wish to make it work this way:
lModelList = FBModelList()
lModel = FBFindModelByName( “model_name” )
lModel.Show = True
lModel.EnableTransformation= False
Anyone has any idea?
p.s the Enable Selection is the Pickable property, still nothing about Transformation
Found the solution for what i was looking for, basically I needed to lock down the bones of the skeleton, and allow control over the control rig only.
It’s a really odd way of doing things but it works:
lModel = FBFindModelByName( "bone" )
lProp = lModel.PropertyList.Find( 'Transformable' )
if lProp:
lProp.Data = False
Hope it is of use to others as well.
If anyone is looking for a way to search for all the children under a certain node(FBModel type) this is how I did it:
def hierarchy(lModel):
for child in lModel.Children:
lModelList.append(child)
hierarchy(child)
hierarchy(lModel)
