there are a ton of syntax highlighters out there for javascript, theres no reason to do that on the server.
That sounds amazingly obvious and yet blows my mind. This would make a server a pure data-provider which makes the most sense to me. Why are folks using server-side templating to begin with? Is it simply an older way of doing it? Sounds like it would suffer from much higher bandwidth as well. Does this make something like Jinja2 completely useless?
We’re actually using django as we have a central web server and we can add different apps as needed. We use it for all sorts of stuff, for use with angular we have monitor apps for our build and bake farms. Angualr makes all of this ridiculously easy.
That makes me happy to hear. Sounds like this is the way to go.
I just define my api by the urls in one place so its very clear as to what can be done and which functions do what.
That’s a bit above my head at the moment, and although I believe Flask encourages the use of decorators for routing, it is Python after all and I’m sure the method you speak of could apply equally well here.
you may find this useful to test your REST api
Once I get a little further into actually creating and using anything RESTful, I’ll keep this in mind, thanks!
What sort of studio are you in, film, games, commercials? With “build and bake farms” I’d assume a film facility.
